This command has been replaced with the following command: configure l2vpn [vpls vpls_name | vpwsvpws_name] peeripaddress [limit-learningnumber | unlimited-learning] .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Configures the maximum number of MAC SAs (Source Addresses) that can be learned for a given VPLS and peer.
| vpls_name | Identifies the VPLS within the switch (character string). |
| ipaddress | Specifies the IP address for the peer node that is the endpoint of the PW-LSP. |
| limit-learning | Specifies a limit to the number of MAC SAs to be learned for the specified VPLS and peer. |
| number | The maximum number of MAC SAs that can be learned for the specified VPLS and peer. |
| unlimited-learning | Specifies no limit to the number of MAC SAs to be learned for the specified VPLS and peer. |
Unlimited.
This command configures the maximum number of MAC SAs (Source Addresses) that can be learned for a given VPLS and peer. This parameter can only be modified when the specified VPLS is disabled. The unlimited-learning keyword can be used to specify that there is no limit. The default value is unlimited-learning.
The following example causes no more than 20 MAC addresses to be learned on VPLS1‘s PW to 1.1.1.202:
configure vpls vpls1 peer 1.1.1.202 limit-learning 20
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
